It is currently Fri Sep 19, 2025 5:08 am
PostPosted: Thu Jan 14, 2021 10:36 pm
Last Name: Livermore
State: Minnesota
With all the chatter about finishes lately, I have a serious question for our pro finishers.
Would you rather go in the booth multiple times to spray nitro or twice to spray cat polyurethane?
Realizing that neither are particularly good for a person’s health, One has to wonder what the lesser of evils is here?
Please advise
PostPosted: Fri Jan 15, 2021 12:09 am
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
HI Dave,
In my opinion, you don't want to apply either of these finishes if you are having to choose which one is the worse for your health. Only apply these finishes if you can do so while suffering absolutely no harm to your health. If you are protected, then it doesn't matter how many times you are going into the spray booth. In other words, you ONLY want to use these finishes if you can apply them safely. Both are quite toxic !!!
BUT I do know what you are getting at here. I think the catalyzed urethane might be worse - with the isocyantes in the hardeners potentially life threatening for some individuals who might be sensitive to it. A lot of folks spray this stuff and throw caution to the wind -- and they are fine -- and some get cancer or get rushed to the ER. I'm not willing to take ANY risk !!! I've got a sufficient spray booth that captures all the overspray. I'm wearing a Tyvek spray suit, latex gloves, and a full face 3M respirator with fresh cartridges. Nothing gets on me while I spray. My shop smells bad for a day but when I enter it -- I'm decked out in the PPE.
I think the Urethane might be a bit easier to apply just because you don't have to shoot as many coats. But then again, there's a bit more sanding involved because you must have mechanical adhesion rather than chemical adhesion between coats. But I've found the sanding fairly painless. I also think the urethane is a bit better or the environment -- the chemicals catalyze and therefore, lose their toxicity. You do have the solvent carrier but urethane is a fairly high solids paint. However, with the amount of finish we apply -- environmental concern isn't that high on the list.
I think the main reason lacquer can be easier to apply is that you never have to worry about witness lines - it's easy to spray and relatively easy to keep thin. It's super easy to level and buff. Urethane is a bit more work in some regards but also easier in others.
One consideration is that VOC's are the things that linger in your shop and nitro has got more of those. Bar none, the worst thing about the urethane for me is the MEK smell -- it lingers but is mostly gone by the next day. If it helps any, I believe urethane is easier for me to spray safely. I don't believe I could apply lacquer safely in my current shop setting.
These users thanked the author Toonces for the post: Barry Daniels (Fri Jan 15, 2021 11:13 am)
PostPosted: Fri Jan 15, 2021 12:17 am
It's not about toxicity. It's about following all the safety rules for shooting whatever finish you choose. Be smart, and live.
These users thanked the author Chris Pile for the post: Mike OMelia (Mon Jan 18, 2021 1:04 am)
PostPosted: Fri Jan 15, 2021 1:05 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
From what I have read, I think catalyzed finishes are more dangerous during mixing and spraying, but they become relatively harmless in a few hours, whereas nitro stays dangerous for weeks. I can take extreme precautions for a few hours of mixing and spraying, but I can’t take extreme precautions for weeks at a time. So, in my view, catalyzed wins the safety contest (despite being more dangerous).
PostPosted: Fri Jan 15, 2021 1:37 am
First name: Toonces
Last Name: the Cat
State: FL
+1 to what Don said. A whiff of any of these things isn't going to kill you. Splashing it on your face/eyes or ingesting is a different matter altogether -- but just getting a little bit on you isn't the worst thing in the world so long as it happens very occasionally. The biggest issue with spraying is that you are atomizing this stuff and without proper ventilation -- it goes EVERYWHERE. So if you protect yourself, have proper a spray booth that effectively moves the right amount of air -- then you can spray either of these without problem. If you can safely deal with lacquer offgassing -- then both options are on the table for you. Personally, I wanted to see if I can get the tone I seek with urethane -- if so, I believe it is a superior finish to lacquer unless you build for the traditional crowd.
Feel free to give me a call if you undertake the urethane. I'm more than happy to help !!!
Simon Fay (contact information is on my website)
PostPosted: Fri Jan 15, 2021 5:21 am
One of the best painters I know worked for LearJet for 35 years. He said the deadliest stuff he ever worked with was Imron.
PostPosted: Fri Jan 15, 2021 7:07 am
First name: Victor
Last Name: Seal
City: Osseo
State: MI - Michigan
Zip/Postal Code: 49266
I sprayed nitro once. Never again!!
PostPosted: Fri Jan 15, 2021 12:06 pm
With Nitro, when you can smell it through your respirator it is time to change your cartridges. With 2K PU if you can smell it , it is already too late. To use cat polys it is recommended (required) to have a fresh air supplied respirator (preferably a full hood to also protect your eyes).
Like epoxies, polyurethane is a sensitizer so avoiding even skin contact is recommended. Some people have acute reactions to it after becoming sensitized.
Nitro destroys your organs a bit more insidiously, like over consumption of alcohol (in combination, a one two punch [:Y:] ).
With Nitro and cat poly it is the adjunct materials that seem to do the most harm - solvents, thinners. and catalysts.
We picks our poison and takes our chances.
Brushing a waterborne finish is the safest bet, but the limited contact we have finishing guitars nitro and poly is probably not going to kill us (right away gaah laughing6-hehe )
These users thanked the author Clay S. for the post: Pmaj7 (Mon Jan 18, 2021 7:24 pm)
PostPosted: Fri Jan 15, 2021 12:32 pm
That's why I like stuff like Watco or TruOil....
PostPosted: Fri Jan 15, 2021 3:18 pm
State: Minnesota
Thanks for,the responses. Good stuff to think about.
Like Toonces, I’m searching for an alternative to nitro.
I would French Polish EVERYTHING if people wanted that. But it is so fragile on steel string guitars.
My nitro technique is just fine. I lay down a nice thin layer, but it’s so time consuming.
This is why I tell people that once I have a closed box in the white, I’m only half done.
PostPosted: Fri Jan 15, 2021 3:20 pm
Are you saying two coats of urethane is enough?
PostPosted: Fri Jan 15, 2021 6:47 pm
all finishes can be toxic use a proper spray area
Nitro is fine with the proper protection
I agree change your cartridges often
PostPosted: Sat Jan 16, 2021 5:50 pm
First name: Toonces
Last Name: the Cat
State: FL
Hi Ed,
I don't think 2 coats would be enough -- it's enough if you "base" is already perfect. Here's my basic schedule:
2 Light Isolante Sealer Coats
Pore Fill
Sand Back (exposing wood in various places)
1 Sealer Coat
3 Urethane Coats
Sand Back Perfectly Level (leaving about 1-2 mils)
2 Coats on Top, 3 More on Back
Wait 2 Weeks and Level/Buff
If you went with satin - you could save a ton of time. But a perfect high-gloss is a lot of work regardless of nitro or urethane. Urethane is nice because you don't have to shoot a ton of coats and because it dries very quickly.
These users thanked the author Toonces for the post: Dave Livermore (Sat Jan 16, 2021 8:49 pm)
PostPosted: Sat Jan 16, 2021 7:46 pm
Question was to OP in regards to only entering the booth twice for urethane...
PostPosted: Sat Jan 16, 2021 8:11 pm
You being a Doc and all, it would be entertaining seeing people in future generations trying to decipher what you wrote inside on the top! :)
PostPosted: Mon Jan 18, 2021 1:06 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Nothing wrong with nitro, wear the gear,
PostPosted: Tue Jan 19, 2021 11:45 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
That's only a small part of the problem.
Hutch
PostPosted: Tue Jan 19, 2021 12:03 pm
Maybe doing finishing is not for you.
PostPosted: Tue Jan 19, 2021 1:28 pm
First name: Richard
City: Warwick
State: RI
No, my issue is only with nitro. I've sprayed about 5 instruments with it and it was easy from the get go. They always come out great and I will most likely fall back to this when I can do it outside and let the guitar gas off outside as well. There's about a 6 month window for that up here in the northeast. I've sprayed in the winter outside but don't have any desire to do that again so I'm going down the waterborne path with a brush, no annoying compressor.
Hutch
PostPosted: Mon Jan 25, 2021 4:35 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Please advise
In my opinion no more than nitro.
The difference is 2k urethane makes you a bit sick if you spray it without any protection. A 3M mask is enough to stave off any symptoms from it (I mean the cartridge stuff, not the N95 medical mask for COVID).
Nitro doesn't really cause sickness apart from some headaches if you sprayed it without protection but neither is too good for your health in the long run.
But in Taiwan I see everyone spray the 2K stuff (I got a few auto modification shops nearby) with little more than a N95 mask and they seem fine.
Typhoon Guitars
PostPosted: Mon Jan 25, 2021 10:44 am
Yeah, there are no long term health effects from cyanide poisoning. Unbelievable.
Users browsing this forum: No registered users and 42 guests
